Which TV tuner for HTPC?
7 Sep 2007
Edinburgh
What is the best TV tuner for around £30. I will go higher if recommend.
It will be used with Vista Media Centre.
Will the picture quality be as good or better than the internal freeview on a Samsung LE32R87 LCD.
Thanks.
Get a dual tuner. You'll soon get peeved at not being able to record one channel while watching another.
I have the Compro E700, works very well with vista.
Whats the picture quality like? How does it compare to your internal freeview on your LCD?
Thanks,
Johnny.
Thanks,
Johnny.
I would have to say the internal freeview is slightly better, but I think this is more to do with the settings on my ATI 3650 (looks like there is a little to much processing going on) but I can only notice it up to 1m, not from where I sit.
I'm using it with a plasma so I don't know how it will look with your LCD.
