Hey,
I'm really sorry to ask a question that's been raised a hundred times before but i'm really struggling.
Before anyone comments - i have used the search function on the forums and i've exhausted google to the point of no return.
I'm hoping you good people can point me in the right direction as i'm pulling my hair out at the moment.
I purchased the AM200 and WRT54GL recently being advised that they are a great combination in functionality and security. I upgraded the WRT54GL to the most recent tomato firmware and left the AM200 with the normal firmware that it came with.
I have tried every combination of PPOA, full bridge, half bridge but can't get the modem and router to talk properly.
The idea was to have the modem on 192.168.1.1 with PPOA, though it forces me to type in username and password which means i get failed internet access as 02 is blank. I then tried bridged mode which half works but doesn't hand over internet access to the router.
the router WAN address was set to 192.168.1.2 and LAN to 192.168.0.1 with DHCP enabled.
Not sure if i've explained myself properly - but there's so many options on these units i don't know which i need or not.
Friend of mine suggested i just switch on DHCP on the modem and just use the router for wireless. To me that seems that i'm bypassing the security of the router all together which seems a real waste.
any advice greatly appreciated - or if someone has this setup on 02 i'd be happy to see your config
Cheers in advance.
Yimpy
Cheers in advance.
Yimpy
