Canon 40D video Capture
18 Oct 2002
Chesterfield
Just tried it on mine, quality is very good 1024x680, a screen cap below, no sound or auto focussing, but not bad :)
http://forums.dpreview.com/forums/readflat.asp?forum=1019&thread=30778943
Yup was reading about this today, will be trying it tonight with the 40D connected to my netbook and netbook connected to "me" LMAO :p
Yours was posted before mine which is why you wouldn't have found it when searching :D
I imagine you could use a usb extension cable :)
No i meant i did a search before i posted mine :-) anyhow it doesnt matter, get shooting some video :D
Yes good idea, just wanted an all in one cable really, not sure if signal degrades over length
It shouldn't do, after all it is a digital signal.
As to shooting some more, I'm gonna be pretty busy for the rest of the night, but hope to have a good play tomorrow :)
So you can use it as a webcam?
Doubt it would work, this only works with the piece of software you download. I guess in the long run someone could get it working along with msn and other apps.
I take it Live View is needed for this to work?
Yeh pretty certain this is the case.
Yeah it can be done. This has been hovering around for some months. I read it ages ago on something but this was listed on engadget today.
Works a treat.
The 40D can't capture video, its just the software recording what you can see. The Canon software has the ability to stream live view to your pc but not as smoothly as this does.
There is nothing but a start and stop control and it forces your camera into live view upon launch. Very simple and effective software.
I uploaded a video sample to show the quality, this was an ISO800:
It's VERY high quality even though it's not HD resolution it has the sharpness and smoothness of a HD video I'd say especially at lower ISOs.
I can only imagine what raw 5D mkII video is like!
My video seems to have some speed issues due to being recorded on a netbook, makes for an interesting "effect" though :p
(click in for HD 720P!)
I tried walking around with the netbook attched recording like a camcorder but....no go!
I soon realised the flaw in this plan, the netbook needs to be open at all times not tucked away in a manbag as the camera's LCD is disabled during liveview via cable :(
what did you use to encode that? I can never get youtube right
Windows Movie Maker :)
Try hitting the set button on the camera (or whatever button it is you do to start live view normally)
I can get the view showing on both camera, and my pc with my 450D.
Can the 40D focus during live view at all? I've trie it on my 450D, and although it will focus with either the mirror flipping down and focusing like normaly, or using the live focus, both seem to loose feed of the picture to the pc.
mrk - how do you get movie maker not to shrink the res - I can't see an option to choose something more complex than saving at dvd res or similar when saving the file?
Pressing set button does indeed show it on both pc and LCD but it won't record this way, recording has to be initiated by the software on the 40D it seems so no LCD+PC dual view.
I used VirtualDub to add a 16:9 crop filter at the original resolution width then exported as raw AVI then used Movie Maker to save as 1280x720 (720p) :)
This is Vista movie maker btw, standard movie maker does not support higher resolutions.`
