waterblock for GTX 285 ??
I just found that they have diffrent pcb
so it looks like I will have noisy rig again :mad:
I'm in the same boat. The 280 block won't fit. XSPC, Koolance and Aqua-PC have some 285 ones on the way, should be out in a week or two.
The Ek waterblock is available to order now.
I have placed my order for the Nickel plated version already :D
do you guys think that they will fit all brands of GTX 285..?? because some time ago i bought 8800gt waterblock wich wouldnt fit my 8800gt..
i just found that: "BFG proudly presents four overclocked GeForce GTX 285 graphics cards. The cards respectively increasing in clock frequency and price, will be branded OC, OC+, OC2 and OCX. BFG has decided to use the card's reference PCB-layout and cooler, only changing the sticker." if its true than everything should be fine.
Was that full cover? This is where core only blocks come into their own. You can also re-use them on upgrades unlike the full cover blocks which you have to change when you change card.
