2433BW vs T240
8 Sep 2005
Chichester
I bought a 2433BW about a month ago, and want to replace my 19" with another 24". While im very pleased with the 2433, is the T240 worth the extra £40? The specs seem identical from what i can see.
T240 comes with the HDMI hence the extra cost, so unless you want to make use of it, then it is worth it. Either way these Samsungs are nice monitors.
ahh also i think the T240 has USB ports on the screen?
correct, 1 up, 2 down USB hub. using it for my £1 woolworth webcam (that can not even make out a shadow) and Logitech G5.
T240 also have a plat on the back, where you can stuff all your long cables in it and close it for tidiness. i stuffed the long G5's cable into it, and also part of my iPhone dock's USB cable.
