Two brak calipers on one disc?
5 Jul 2007
London
Hi there,
I've seen a fair few aston v8 vantage's around in the past, and have noticed that they appear to have on the rear disc, one large brake caliper in usually coloured, and a smaller black caliper like thing. I just wondered what this is used for?
Is it to clean the disc or to remove water, or what else could it be for?
Here is some pics i found on the internet.
Tom.
because most rear disc cars have an internal handbrake mechanism on the inside of the disc operated by 2 brake shoes.others have a 2 in 1 rear caliper which works hydraulically and mechanically bu the bigger the discs the harder it is to make this work
You haven't seen the size of the discs/wheels to say the black one is small.
Seems a bit pointless... added weight and cost.
Why don't they just do it like every other car does it? Have a rear caliper that supports both hydraulic and cable?
Because after the cars had a good spanking the large surface area of the pad is very warm, stop the car and clap the pad to the disc and you leave your wallet in all sorts of pain, having a much smaller surface area on a cold pad means its less likely to do this + it also means you don't get people running to Ferrari asking why my car has rolled down the hill.
I suspect it may be due to the heat of the brakes? These cars are designed to do some speed and the brakes would get tortured if you drove the cars properly. After a session, applying the handbrake on the same brakes you've just been abusing could cause a few problems with pads bonding to disc etc. Just a hunch though. It's usual track day advice for an average not to apply the handbrake will the brakes cool down so maybe this is just a posh track day aid?
Oh that is a good point :) Good fool proof way to stop warped discs...!
Yea, barring the handbrake thing, you can run twin calipers too for braking reasons (or as many as you could fit if you desired!) - my Sprint has twin front calipers for example. This isn't a standard thing but the upright is designed to carry twin calipers and consequently it's a bolt-on job.
Problem is it enables you to dump so much heat into the disc and calipers that fade is reputedly increased - not that I've tried, yet! :)
Also increases unsprung mass but that's lessened if using aluminium calipers anyway.
Get some good quality ducts sorted out and it should help cool the disc, interested to see this lashout never heard of a car having the option to fit twin braking calipers.
