I turn everything off now. It saves me approximately 240w/day, which isn't a lot, but it adds up.
Though in reality it only saves me about £1/month.
U sure it is as much as 240w per DAY?
Most units use less than 1 or 2 watts on standby.....
Repeated switching on and off electrical devices will break them sooner rather than later. They don't like cold starts as this stresses powersupply components and ultimately will lead to failure.
I changed my HTPC to a low power version and that now draws 5w on standby. This would give 232w/day.
Remember that i do not have much kit, just a HTPC, TV, HiFi amp, and tv signal booster. Most people will probably have more than that... Sky/freeview box, games consoles, more powerful hifi, etc...
So yes, 240w/day is not 'impossible' it is infact quite low.
That doesn't make sense. The watt is a measure of the amount of power that's needed to do work - it measures the rate at which energy is consumed, not the total amount of energy which is used. It's like the difference between the speed at which water comes out of your tap and the amount of water that collects in the sink.
Your leccy supplier will bill you for the number of kilowatt hours (kWh) that you use. If your gear uses 200w and you leave it on for an hour, you'll use 0.2kWh of leccy. If you leave it on for a day, you'll use 4.8kWh.
What doesn't make sense?
Me turning my HTPC/TV/HiFi/etc... off at the plug saves me approx 240w/day. Which is a saving of about 3.5p!
If something draws 5w/hr and is on for 16hrs a day that is 80w over a day, or 0.08kWh.
I might not have the terms exactly right, but i do know exactly how much power my flat uses each day, and what it costs me to run. I also know almost exactly what each item costs to run, and can very easily predict power consumption.
This comes from getting an obscene electricity bill and over analysing everything
If we take my HTPC as an example i can tell you what it costs me to run, and how much i save per month turning it off at the wall. The machine is 5w standby, and approx 60w in use (60w is an average taken over a long time period).
Therefore per day (say it's on for 8hrs) it will use: 5x16+60x8 = 0.56kWh. This over a month gives a cost of about £2.40.
If i turn it off at the wall: 60x8 = 0.48kWh. Which over a month is £2.04.
So me turning if off saves me about 36p a month!.
Mattus is right I'm afraid, you can't "use" any amount of watts in a day. A Watt is a rate at which you're using electricity (IIRC its joules per second), if you're drawing 5W it makes no differance what timescale you measure it over, its still just 5 watts. The problem is that the electricity industry has invented a nonsense term kWh, which really just 3.6 megajoules.
You're general sums are ok, you will save that money, it just makes no sense to say that you're using 240w per day.
anyway, thats enough pedantry, I know what you mean.
And for the record, I leave everything on standby/sleep, as I reckon it saves me many joules in getting off my fat arse and walking to the TV cabinet
I would love to know how much im saving by turning them all off at the mains....?
