Bottleneck
9 Oct 2008
Somerset, UK
Hi i am soon upgrading to a 4850/70 (not sure yet) and a phenom II atm i only have anough for one and i was thinking of getting one whilst there cheap. Even if it dont put it in my system now.. if i did do you think either of them would bottleneck my current system?
Why are you looking at upgrading? Are you struglling with anything yet? tbh your system doesnt look to bad as is, I wouldnt of thought either would give you massive gains. If you were to go for it though I'd recomend the gfx card, if its gaming performance you're looking for, but then what size screen/resolution do you use? Your 3870 may well be good enough
atm 1360x768 but thinking of buying a new screen later on in the year and yeah that 4870 is cheap this week.
And your right lol i dont really need to upgrade. I just want to but i proberly shouldnt.
