Long rod question
17 Nov 2003
St Breward Cornwall
im sure its something you all wonder about but if i have a metal rod 10 miles long and pull it at say 1 metre/second how long before the other end moves assuming its frictionless and wont stretch, ok its not instant or speed of light so how fast is that motion transfered :)
If its frictionless and it doesn't stretch, then it moves at the same time as you pull the end you've got in your hand.
Unless this is like that plane on a treadmill question.
Does it matter seeing as no one is going to have a metal rod 10 miles long and even if they had would they be daft enough to try and pull it?
I've got a metal rod that's 4 feet long though and it doesn't take much pulling. Is that any help? :D
It would be instant. Well, instant to you anyway.
V = s0 / at
S = s0 + 1/2 (v0 + v)t
S = s0 + v0t + 1/2 at^2
V^2 = V0 ^2 + 2aD2
S = S0 + VT - 1/2at^"
where...
v is the body's initial velocity
s is the body's initial position
and its current state is described by:
v the velocity at the end of the interval
s the position at the end of the interval (displacement)
D the time interval between the initial and current states
a the constant acceleration, or in the case of bodies moving under the influence of mavity, g.
Why is it assumed to be instantaneous at what is effectively a very low frequency (you pulling it) as compared to the speed at which it would transmit higher frequencies (sound waves)? Is it because it's below the "breakup" frequency of the material (term borrowed from speaker cones!)? Surely at that length this frequency would be extremely low anyhow.
Depends if you're pulling toward or away from the greenwich meridian...It could 'move' before you pull it, based on local time...If the pole's long enough.
*n
A more avant garde view might be that it moves at the speed of electricity since it is electrons that give hardness to a material and they in effect could be thought of as transmitting the movement in this case. This would place it below light but above sound in speed terms.
and if you pulled it say 1 foot but the other end hasnt moved yet is the length of the rod now 10 miles and 1 foot?
