I'm still bumming around off work and glued to Freecycle like a junk hoarding jippo. Today I managed to score a junked mini moto
It's pretty snotty but it's almost complete and the engine turns over. Plenty of rust so I reckon it's been at the bottom of someone's pond or shoved behind their shed. More pictures...
Clutch is a bit snotty but sort of moves and I think a bit of WD40 will free it up:
Rear gear and er, stuff, really rusty but nothing a bit of WD won't fix:
Ah well you can't see down here but it's full of stagnant water, mayonnaise and a snail:
The pull start is missing which is a bit of a jip but it looks like you can get them on eBay for under a tenner delivered. Foliage came free with the bike:
Front brake is present and looks like it'll work with a bit of fettling:
Back one is missing the caliper but I can work around that and just use one brake
This is the bit I'm interested in, the engine. Turns over, seems to be complete apart from the pull start and has a little compression:
I haven't had the carb apart but my first worry was the tank being full of slime and all that being in the carburettor. I may have got lucky because there's a fuel tap on the carb and it was in the off position, so you never know...
It even has an exhaust with a little expansion chamber ;D:
Anyway plans are to chop it up, merge it with a bike and make into an ultra cheap two-wheeled terror to take to Lemans in a few months. I'll try and get the engine going but if it won't run then no loss, I'll use some of the other bits and make a push bike instead.
So far the plans are it'll use the 4ft ape hangers off a small blue chopper bike I made and I think it has to use the wheels off the mini moto. Need to get my sketch book out...
And while I've been typing this I've scored a couple of junk bikes to pick up in the morning too. Happy days
