After reading up on the differences (vague curiosity stemming from the 'rod' thread) I've got a question hopefully one of you can answer.
Am I correct in thinking that of two engines with the same air intake size, a turbojet will create more thrust but use more fuel than the equivalent turbofan engine? (i.e. therefore turbojet has higher thrust/weight ratio but less economy?)
Also, why would you bother with a turboprop when you could have a turbofan?
