Black Screws Needed...Help?
Yeah, gas hob will work fine
Here is how it will come out
The parts that are patchy at the top and the spot in the middle are casued by silver solder
Can you do a quick guide for this? Might give it a go as I tried spraying some last night and the paint comes right off. I didn't give it an hour between coats though so I'll have another go at the weekend.
I find it absolutely amazing that you can't buy any.
RoEy
Did you clean the screws before painting?
Hell even baby wipes can clean pretty good.
Any grease from fingers or other things, might stop the paint from bonding properly.
Morning Al,
No I didn't mate. Just quicky gave them a test spray. They were sealed though and haven't been used. I'll give it an hour between coats though like you suggested. £7.49 down the drain otherwise...
RoEy
Hmm, I think I'll spray paint some screws and PCI brackets this weekend and upload the pics for you. :)
Watch my log so. It's needs an update anyway :p
