As posted by me on CTRO:
I did use National Tyres for my oil change, but I'll eat my hat if that's the problem. I just think it's down to 'user error'!
Any thoughts?
Hi all,
I managed to send my car into a bit of a hissy this evening.
I have a bad habit of only turning the key in the ignition for just long enough for the engine to 'catch', and the problem is sometimes it doesn't. I've done it a few times recently, and what usually happens is it runs lumpy for two or three seconds and cuts out, to start again straight away on the next turn of the key.
This evening was a bit different though. I did the same thing where the engine didn't 'catch' properly and it started to run lumpy. Only this time it carried on running lumpy (it was below 800rpm). It stayed like this for about 10 seconds, after which I floored/pumped the accelerator pedal for a few seconds. Nothing happened - no rise in rpm, nothing. Just an idle chugging. At this point I thought 'oops' and turned off the ignition.
After a few more seconds, I turned the key and held it there properly. The engine started and it ticked over as normal, but this time the engine light came on and it stayed on. I carefully drove off and as the car warmed I gave it a bit more throttle. All was fine. I hit the A23 and gave it some VTEC yo' action with no issue whatsoever. 15 miles later I arrived back home with the engine light still on, but none the wiser to what the problem is and the car still fine and dandy.
I'm certain it's what I did by nont letting it turn over properly on ignition, and everything else is fine. Oil was changed on Saturday about 150 miles ago, and everything else is as was.
I'm just confused and think maybe I've fooled the car into thinking it's got a problem. Has anyone else experienced this or something similar, and if so, what was the problem/cure? :vconf:
Any thoughts?
