Some very odd looks - one dude kept orbiting at a distance to try to figure out what was going on. Eventually you phase it out and get on with it.
You're not. I had the absolute perfect chance of shooting two "vagrants" on a park bench, complete with can of larger and black and white scrawny pooch at one of their sides. The park bench was under cover of like a bus shelter thing that would have framed the shot perfectly. They were wrapped up warm chatting to each other and had the glummest of looks on both their faces.. Just perfect
I bottled it..
LOL a very patient fiancé - a couple of laptops and a couple of wooden spoons rammed in the drive baysIt's a combination of around 20-25 exposures.
It has been a good turn out for the start of the season, lets hope we can keep it up! which means we need top theme choices from you guys (if you win that is)![]()
That's Russell Square as well isn't it? I walk through there every day to work.
I like how you have interpreted the theme... fantastic entry and will be hard to top
I'd be keen to go for a photo walk or something similar. I struggle sometime with inspiration in London even tho there are so many things to see and do. Are you a local as well or do you train in?It is indeed - I live on Southampton Row so it's kinda my localI'd be keen to go for a photo walk or something similar. I struggle sometime with inspiration in London even tho there are so many things to see and do. Are you a local as well or do you train in?
Cheers for the kind words.
I am always hunting around that area down the side streets, near the "Horse Hospital" for example.
I train it in daily and work on Percy St, just off Tottenham Court Road so would be up for some street photography if you are game. Soho and around the bars that network Goode St are good for candids at lunch and later in the day.
You aren't one of the joggers i see in the evening are you Steve?![]()
Changed my entry again - British Museum by day with some Tilt&Shift magic applied
Cutting it close Willis![]()
Just thought I would throw it into the mix.
