Vram usage?
2 Jun 2007
Mornington Crescent
Is there a way to see how much Vram I'm using in windows? The two usual methods seem to be Rivatuner (but this way doesn't work in Vista) and ATI tray tools which needs an unsigned driver... Are there any other ways to see how much is being used?
Running Vista 64, if it helps.
Thanks!
Thanks!
where in rivatuner is it, i cant find it
running vista 64
running vista 64
Hi, check what I said in the brackets riiight after I mentioned Rivatuner ;)
But for reference, go into hardware monitoring, hit setup, then plugins. Finally, select VidMem.dll
