any ideas how to remove hard drives from my Thermaltake Mozart TX Case ?
Permabanned
26 Jan 2009
Some one built this PC for me so I have no idea all I no is the drives wont pull out the bays and I cant see any screws to unscrew.
Any ideas ?
Most thermaltake cases have 2 thumbscrews holding the drive cage/bays in place take them out, then you will have access to all the screws for the drives. Dunno if this is the same for the mozart.
Cage at top has 2 thumbscrews? If you can't see screws for your harddisk maybe they are screwed in at the otherside.
Best image I could find on net to explain :p
The Mozart HDD cage has three thumbscrews (two at the bottom and one top). There is also a catch on top of the cage above the top HDD space.
Other wise go to the Thermaltake website and RTFM.
Hahaha cool, anyway wonder if the dude managed to get his hdd out :p I'm kinda a bit worried about him taking his pc to pieces when he couldn't figure out how to remove hard disk bays.
Thank you so much every one. not home for a few more months so Will give it a go then. Sure i didnt see any screws thou like on that cage, maybe they were coverd over with something.
Will check soon!
