Checking RAM Model
13 Jun 2008
Hey. I got this PC for free recently and it has 2GB RAM, I'm looking to buy another 2GB. I wanted to make sure to buy the correct one, because it has to be the same model right. Heres some CPU-Z screnshots:
Does OCuk sell this model?
I think this is it though Overclockers only sell the dominator version so could be a difference in heatsinks if that worries you. Ram does not have to be the exact same model though it would help in case of any compatibility issues I think.
http://www.overclockers.co.uk/showproduct.php?prodid=MY-119-CS&groupid=701&catid=8&subcat=817
thats would work mate, just set the timmings in the bios manually, as you will have all 4 ram slots filled you might just need to up the northbridge and ram voltage a tad, say by 0.1v to stablise and supply a good amount of power.
:p
Thanks mate, and isit always better to use 64bit OS's when having >= 4GB?
If you plan to use more than 4gb then use a 64bit os as a normal 32bit os can only see a maximum of 4gb ram including how much memory you have on your graphics card.
