Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
looks way too wide for the 50mm cropped.
50mm F1.8, probably a Canon one judging by the slight edge softness.
It's all a trick, he's bought a tripod or battery grip lol
Narh, its a lens
Only 1 correct answer so far![]()
Narh, its a lens
If it is what I think it is you'll want to check for focusing issues, I've read multiple reports of badly focusing (...err...) samples with the response from (...err...) the manufacturer being that a run was assembled without spacer rings and though they acknowledge the problem they won't be making an official announcement. The main check is whether the zoom goes past infinity as it tries to focus. If it's good to go I'm sure it's a great lens and I'm tempted by one myself.
What do you think it is ?
If you've seen the EXIF then it is very easy to tell![]()
