I tried 400x8 = 3.2ghz with all voltages bar ram and cpu on auto. It passes orthos and 3d mark and prime but STILL fails on the intel burn thing and games still spot responding shortly after playing
That's your Northbridge carping out, just imagine trying to really overclock your CPU without supplying it enough vCore . . . what would happen? . . . well you are doing basically the same thing but instead you are overclocking the Northbridge chip, give it some volts for the love of god!
As I write this I am at 400x9 = 3.6ghz @1.5v, ram at 2. and everything else on auto - Orthos ran for 1min, it did not fail but was not happy about 74degrees so I stopped it
Hmmm that does sound like its getting toasty!
Have you tried dropping the vCore slightly and seeing if its still stable? . . . Would be really good to know if 3.6GHz (9x400) is rock solid, other than dropping the vCore is there any way you can get a bit more airflow to the CPU? (take the case side panel off, open a window etc). I'm not trying to get you to fry your CPU but if you can temporarily increase the CPU cooling for testing purposes it would let us know if that overclock is stable. If it is stable then it just may be a matter of buying or modding up some better CPU cooling!
I have tried manually setting all other voltages but no difference.....this should be an easy fsb to reach as the motherboard does 400 as standard
It is an easy FSB to reach if you have the right CPU and a good understanding of how the hardware works and you know your way around the BIOS etc!
Your practically there although I suspect your running out of patience a bit and getting a tad frustrated. I reckon you can get your 3.2GHz(8x400) overclock stable by just giving the Northbridge some extra volts or your 3.6GHz(9x400) overclock stable by adjusting your CPU cooling and perhaps lowering the vCore a smidge!
Also why would the load on the northbridge go up when the multi is lowered??
It's not that easy to explain but I'll give it a shot!
When you peel away the generic layer we call
The Northbridge there lurks a strange thing known as the NBCC (Northbridge Core Clock). . .
The NBCC basically generates the FSB Frequency, higher the frequency the more voltage it needs and the hotter it gets, very similar to how you may think of a CPU.
Now the interesting bit . . . for the NBCC to work out how fast to run it performs a quick bit of maths like so
- Default CPU Multiplier divide by Set CPU Multiplier = A
- Set FSB = B
- A x B = NBCC
If we use your E6600 running on a 400MHz-FSB as an example you may be able to understand a bit better
Default Multi = 9
Set Multi =
9
Set FSB = 400MHz
9 divide by 9 =
1
1 x 400 =
400MHz NBCC
Default Multi = 9
Set Multi =
8
Set FSB = 400MHz
9 divide by 8 =
1.125
1.125 x 400 =
450MHz NBCC
Default Multi = 9
Set Multi =
7
Set FSB = 400MHz
9 divide by 7 =
1.285
1.285 x 400 =
514MHz NBCC
The NBCC is designed to run on average at 333MHz to 400MHz and have the motherboard take care of the voltages. As you can see above in the highlighted E6600 examples once you lower a chips multiplier from default the NBCC frequency starts flying through the roof!
I'm sure this may well not make any sense to you and I don't think I explained it that well but basically once you understand how the NBCC works you begin to see that for a better chance of achieving a high FSB overclock you either need a processor with a
natural low stock multiplier or a sound knowledge of your hardware combined with some enhanced Northbridge cooling!
