Permabanned
- 16 Dec 2008
im going to order another GTX 280 although OCuk dont stock them anymore, after all that waiting
im a total noob to Sli, just wondered if someone could help..
some people have told me that i can use any GTX 280 at all, as long as its a GTX 280 and it will work with my POV... i thought i would have to have identical cards.
so anwyay, i cant find identical cards but i can find almost every other GTX 280 that isnt POV...
so can someone confirm if i can buy any GTX 280 and put it in with the standard POV?
my POV is just standard,...
Video Memory : 1024 MB
Core Clock : 602 Mhz
Memory Clock : 2214 Mhz
Shader clock : 1296 Mhz
Memory Speed : 0.8 ns GDDR 3
Memory Bus : 512 bit
RAMDAC : Dual 400 Mhz
Stream processors : 240
im pretty sure the Gainward is exactly the same, which i can get... but if i wanted would say the EVGA SSC Superclocked edition work?
648 MHz GPU
240 Processing Cores
400 MHz RAMDAC
Memory
1024 MB, 512 bit DDR3
2322 MHz (effective)
1448. GB/s Memory Bandwidth
thanks for any input, going to order it as soon as im sure what will work.
648 MHz GPU
400 MHz RAMDAC
Memory
