Coolermaster Sinet Pro users in here please
5 Mar 2004
Southport
I'm still on the hunt for a decent modular PSU that weighs in at well under £100, I know there is a lot of talk goes on about the Corsairs and Seasonics of this world but I want to hear from user of this particular PSU.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-165-CM&groupid=701&catid=123&subcat=1103
How quiet is it, what are you running from it and does it fit in standard cases with that large fan.
Japanese capacitors and a 5 year Warranty are big selling points for me, has anyone had to deal with Coolermaster for any returns?
*edit- Yes, the title should read silent :D
Hi sweetloaf
I have the 850 watt modular coolermaster and it's very quiet.It's a nice power supply.
Looked on the website and the silent pro m700 is a standard size.Will fit most cases no problem.It's the same size as corsair psu's
Hope this helps
Hi sweetloaf
Hope this helps
Cheers :)
The problem round here is that after reading a few too many PSU post you start to get the impression that anything other than a Corsair will go into meltdown if you so much as look at it :)
Quick update.
My PSU is going back to where it came from. The super silent fan has developed an irritating noise which has gradually got louder over the last day or so (sounds like constant vibration) It annoying to the point where I can't shut it out. Seeing as silence was my main concern, it has to go.
Corsair 650W is on the way to me.
