Caporegime
- 11 Mar 2005
- Leafy Cheshire
Quick question for the engineering people amoungst us, some details first :
KO3's turbo @ 21ish psi
51mm turbo outlet size
63mm throttle body inlet size
51mm inlet and outlet on intercooler
If i had a turbo outlet pipe size of 51mm running to the intercooler, through the core to a 51mm outlet pipe, then this 51mm pipe expanding to a 63mm pipe, just before the throttle body, about 20cm long to house the MAP sensor would the increase from the 51mm to 63mm pipe after the intercooler cause me boost problems?
I'm trying to figure if its best to stick with 51mm piping through the system or if an increase to 63mm before the throttle body is acceptable?
Cheers Chaps
Cheers Chaps
(even with the ic).
