- 31 Jan 2009
Please please please don't do a cheap resto on this car.
If what you say is true, a proper resto will cost in the region of £10000 and the car will be worth somewhere in the region of that.
No where near my buddy. I own the car with the two pics that Vigoro has posted. Doesnt get much more resto then that.
Yes if you really do with on buying a new shell. Spending 2000 pounds on a sub frame. A full Newton commercial interior. The list goes on.
You will be hard pushed. I mean I’ve got a car that’s had 42 modifications. With only three of them being cosmetic bar the inside. Engine is next on the list. 7000 pounds total spent by my brother.
Then purchased after an accident (rear end shunt). Re did the brakes and the body it was back to where it was.
Right to add a list of rust points on minis, most common. In no order.
Rear hinge panel
Rear Valence
Rear ¼ at the bottom of the window aperture.
Rear ¼ by the seam that joins the arch.
Rear window aperture
Boot floor
Sills
Inner sills
Floor pan
Wings
Scuttle
A-panels
Door skins.
Another of my family’s minis:
My daily rat look mini, ill take a pic one day. 650kg 118bhp.
