Hey guys, just wanted to know your thoughts about my overclocking logic.
Can i assume that the less voltage you put on the cpu, means that it will run cooler?
So that the cpu is taking in less poewer to run and thus is cooler?
Also, i'm on an i7 920 @3.6ghz 1.3v prime stable
i can get it up to 3.8ghz with 1.34v, but fails prime, the chip just runs too hot
- 95c
my thinking is that there really isn't an application that runs at 100% anyway.
i've run vantage, played crysis and everything is fine, the temps won't get nowhere near as high as prime.
so is it safe to continue with these settings, even though it fails prime, but runs everything else well?
i'm running it on a rampage 2 extreme, with noctua hsf
cheers
- 95c
cheers
