PES 2009 - Game Discussion Thread
when shooting for goal is it just random where the ball gets hit ?? top left, out wide etc ? or are you actually meant to aim when you shoot ?
if i dont press the directional button it seems to go straight to the goalie, not 100% sure what way to press the directional buttons....do you press them in the direction 45deg to the player or just from the screen
i.e if the player is running at a 45deg angle towards the goals (so left stick would be pointing bottom left) do you point the stick to the left or top left to aim to the right hand side of the goal ?
Any news on whether another transfer update will be released following the conclusion of this winters transfer window? Just wondering if its worth making the transfers manually or just wait for an update.
in pro evo 2009, how the hell do you invite someone from your friends list to play a friendly?
Do you have to be in the same lobby, then set up a room, then invite them or something.. as you cant invite then for a 1v1 from the dashboard. ..
explaine it like im an idiot...
