- 19 Oct 2002
- Shakespeare’s County
No, why would i have a MAF in a boost pipe? 4![]()
Did you seriously just ask that?
Never heard of a MAF on the boost side, but tbh i've never read or looked about the subject.
My MAP sensor also seems to be called a Thrust Sensor on various other sites, not sure what thats about?
You know what MAP stands for? Whats that got to do with thrust
and if its in a boost pipe it can't be a MAP sensor by definition, you wouldn't need two on a car anyway as pressure sensors for boost are usually for enrichment compensation of boost on an alpha -N calibration map rather than speed- density.
MAP - The MAP sensor is located in the OE SMIC end tank. There are two different sized MAP sensors, and VW didnt make the transition based on years but cars from all years might have either the small or large version (rumor has it the small version didnt come around till ~2003). When your upgrading your intercooler to a larger SMIC or FMIC and need to specify which MAP sensor your car is running the only fool proof way to check which sensor your car has. If you are making custom piping and need a MAP sensor flange check out 42nd Draft Design for a universal solution.
Rule of Thumb appears to be:
2002 and earlier cars = large MAP
2003 and later cars = small or large MAP
Well yeah, especially as thats the load measuring method on the VAG 1.8T
Yours may be different as you have alluded to, but thats certainly in a charge pipe.
Yes i did just ask that, i've never heard of a MAF on the pressurised side of a turbo system, affraid i can't know everything all the time, just most[/url]
51mm is a bit small for that power output. Expected really as the turbo is also being pushed for that kind of airflow.
You want the larger piping for as much of the system you can get away with, however you also want smooth diameter changes too.
I guess the Cosworth crew must have fluked getting over 400BHP using 51mm boost pipes then.
51mm is perfectly fine for the desired power. You don't want "larger piping for as much of the system you can get away with"
They would have made more on bigger piping though...
Obviously you know more than Graham Bell.
No one has said you cant make that much power, just you are reducing flow rate by having too small a pipe. There is only so much air a 51mm pipe can fit down it.
By going for a bigger pipe you will increase the maximum flow rate, as Graham Bells book states: 51mm is suited to maximum outputs of around 255bhp, this is limitation due to physic and gas flow.
You seem to have misread the comments and think just because you know someone with a cosworth making 400hp then 51mm is the perfect size for that engine.
you have to pair the pipework with the turbo. Larger pipework with the smaller turbo isnt going to help. Sure it may spool up quicker but its gonna take longer to pressurise. What about pressure drop?
Thats the MAF and its not in a charge pipe, the picture you've posted is the output from the airbox to the turbo intake, see ere.
you have to pair the pipework with the turbo. .
