How long is the cure period ?
19 Feb 2007
Northampton
Just got some arcticlean and cleaned both cpu and heatsink, re-applied AS5 and temps dropped by an amazing 10'c, awesome stuff, never really knew how badly i cleaned my cpu :p
Anyway roughly how long should i leave the comp on/off for the AS5 to cure ?
AS5 does not 'cure', it beds in.
They recommend 50->200 hrs use for all the particules to properly fill all the little gaps and surface imperfections. But you dont need to leave it on or off for this to happen.
Infact they need to on/off cycle to help them bed in.
And you will see 2c difference if you are lucky?
Just use it and ignore this 'cure' time nonsense!
I wouldnt recommend overclocking until it is tho, just to be safe.
