I thought id upgraded my bios, but after spending the last hour trying to do so .... i remember now why i havent yet
Ez Flash Bios wont give me access any drive to select the bios file! Ive tried flash drives (as it says in the instructions), usb drives, cds and finally floppies - The floppy controller is in the most ridiculous place, i had to remove my fx card and 2 sound cards just to get the cable in - then i had to remove my floppy drive from the case because the cable does reach :/
So i made a floppy system disk, but on bootup it says its invalid, god i miss dos
Theres a new bios release by the way -
0703, released the 6th Feb ..... maybe some day i'll be able to install it!?
Edit: UPDATE TO 0703 AT OWN RISK!
Couldn't boot using it .... actually couldn't boot after finally getting 0602 to install - had to disconnect all hard drives to get into bios as it kept getting stuck at the S.M.A.R.T. check, which i can't seem to disable - is it possible to disable it?
Anyway, now with 0603 installed, computer feels much more stable, boots (warm/cold) very fast and Windows 7 absolutely flies now
TheMorningStar - What cpu cooler do you use? I was thinking about getting the True Black, but apparently it doesn't fit on this mobo :/
