I've noticed the wing mirror on my driver's side on my MK5 fiesta recently has looked a bit loose & the plastic catches which connect up the mirror to the actual black plastic wall have somehow snapped off too, but the mirror itself is not showing any signs that it is going to fall off but you can basically see that its slightly wobbly, I've got a brand new replacement wing mirror on the way & i have read up on various instructions on the net of how to remove & replace the mirror but some of them say its just a simple case of removing the black cover inside thr car & removing 3 screws, but a lot of the other guides state that you have to remove the whole door panel off as well! So i am a bit confused & would like to ask if anyone on here has had any experience with replaceing these mirrors or even a brief walkthrough of how to safely remove the old mirror & then fit the new one on?
Thanks guys - Liam
Thanks guys - Liam
