- 7 Aug 2003
- Bedfordshire
Hello everyone,
I am after a budget subwoofer - the cheaper the better - between £80-£200 to connect to my Nad c320 bee amplifier.
As it stands, I currently watch DVDs through my PS2 with audio going through my amplifier as oppossed to my television.
I have also found that although my Heybrook HB150 standmounts do put out a bit of bass, sometimes the bass isn't enough, especially for movies and music.
As far as I am aware, I will need to un-link my pre-out and main-in phono jacks and connect these up to the subwoofer with RCA/phono leads.
Specs wise, the size isn't a major issue, but I would like one that does go down to 35-40hz having heard a friends Teac cd player/kenwood av/Wharfedale subwoofer set up!
Thinking of the following:
Pioneer S-W160S-K Active Subwoofer £109.99
WHARFEDALE VARDUS VRSUB SUBWOOFER £124.75
Eltax Liberty Subwoofer £99.95
Cambridge Audio S90 £149.95
Mordaunt Short Premier 308 £107.61
Any others I should consider?
Thank you!
Thank you!
