Project 'Hour Glass'
Nice 'mahoosive' build log there flaremods! :eek: :)
However, just a friendly bit of advice, i'd remove the competitor link/details if i were you. OCUK no likey!
gt
Thanks a lot mate. Where are they?? I removed the one sponsor but thats the only link I could find. I have to leave the banners up there though really as it was a sponsored build. Obvs if it means getting banned then I'll take them down :)
It's the watercooling parts company - unfortunately if you were to leave it up a ban could be what you'd get. :(
As far as i know the others should be fine! :D
gt
Ok thanks a lot, I'm sure its ok if i take it down as the mod was finished and this forum wasnt in the listed forums anyway :).
Thanks for letting me know mate :D
EDIT: done :D
Awesome build. If this was mine i would have had hundreds of things going wrong. Leaks, wrong stuff been delivered, cutting wrong parts of the case etc :p must have done a lot of planning beforehand?
A lot of planning (about 3 months of it :p) Still i had things go wrong like in the end my 240mm rad didnt fit so i had to get another 120mm one :(. Also I originally had a different case but it would work for what I wanted to do so I had to buy a new one :p. I am happy with how it turned out. I supose it needed to be quite good as its my job :p.
great work, looks pretty dam awesome i must say
Thank you very much mate :D
hi,lovely build,look's like a lot of time has been spent on it and a lot of thought.
good on you dude.
just one more thing....you really need to get rid of the competitors name m8....it was on this thread that it was on 9th Feb 2009, 05:07 PM
it was when you spoke to someone on the phone ?
the mods will see it and ban you im afraid.
Amazing mod. Looks like it took you ages!
What else is there to do when it is snowing outside? (In one of your pics)
Well done :)
Not fan of bling-bling and plastic front would surely fail EMC but definitely lot of work great results.
I also touched every join up with some more superglue and filled in some gaps with it too which took about 4 hours to complete
Including also some gluing of fingers I assume? :p
Funny thing how glues always stick best to everything else than the part you're trying to glue.
great build log even if the final colour isn't really to my taste :) seeing the great effort you have put in just makes me want to start rebuilding (and actually plan it)
great stuff!!
wowza, that must have taken a while!
Looks a lot of work, although the colours arent really to my tasts :/
