EVGA GPU Voltage Tuner v.1.0 out!
Download via guru3d
http://downloads.guru3d.com/downloadget.php?id=2178&file=4&evp=a5f9cf8708f446148226aec2b9de1435
Patch for vendor restriction & voltage limit removal :D ( Don't need evga card )
http://forums.guru3d.com/showthread.php?t=287340
http://www.epichardware.com/bin/EVGA-GVT-patch.rar
So far, this patch has been tested and successfully worked with:
-XFX GeForce GTX 260 Black Edition
-2x Leadtek GeForce GTX 280 SLI
- EVGA GeForce GTX 295
- Gigabyte GeForce GTX 260
- Galaxy GeForce GTX 260
- Gainward GeForce GTX 280
- Gainward GeForce GTX 260
- BFG GeForce GTX 295 OC
- 2x BFG GeForce GTX 280 OC SLI
- 2x BFG GeForce GTX 260 OC SLI
- XFX GeForce GTX 280
- BFG GeForce GTX 280 OC
I thought the original issue with oveclocking the 260s was heat? You could send them sky high as long as you kept them cool enough i seem to recall, volt mods seemed ineffective at best. Will be interesting to see how this develops :)
Not really , my 216 sp gets upto a max of 60c without the voltage mod and is unstable beyond 710/1200 ( errors and crash's ). With the voltage mod the temps rise to about 64-68 but i'm at 721/1200 no errors or crashs.
how do i tell what model card i have to see if it is in the supported list?
No offence, but if you're asking that Q you probably shouldn't be messing with GPU voltages just yet.
Do some swatting-up first then let rip.
The program you want is GPU-Z.
this hasn't helped my god awful over clock on my BFG 280oc (allways get the crap card , cpu's i do ok on. upto 1.2 and 1.25 , and instead of the card hard locking with a black screen at 625mhz core it runs but with loads of rendering errors :( , on the other hand keeping at at 615mhz stock ive reduced the the voltage to 1.088 and its rock stable in crysis and folding @ home (much lower temps and power usage as well).
Somthing else must be holding back my Overclock , my Corsair 620 maybe ?
Into the pink benchmark locked up for me @690 core originally. with the voltage increased from 1038 to 1188 I managed core (shader linked) at 760 & memory @ 1280. Scored me 30000 exactly. Temps hit mid to high 70's. Don't think I'd try this for gaming sessions but ok for benchmark fun...
