- 7 Feb 2004
yea those connector pins are horrible, i had to put so much pressure to get them in, after one or two had been put in the others popped back out lol.. was very stressful!
I nearly lost my eye lol
, and seeing as your running IBT id say temps in p95 would be a fair bit lower, also the second fan may give another few degrees drop, managed 5'c of mine when i added a second fan.Nice temp drop, and seeing as your running IBT id say temps in p95 would be a fair bit lower, also the second fan may give another few degrees drop, managed 5'c of mine when i added a second fan.
EDIT, I found spreading across the cpu pretty good, seemed better with my cpu being lapped.
I get that problem as well, the 8 pin cpu power connector on my p5q deluxe is tucked up in behind where my rear TRUE fan is, i normally have to take the top panel of my case and unscrew the psu to get at the cable, this is on a case with a slide out mobo tray (much knuckle skinning ensues if i dont)Yeah mine is lapped as well, will definately do tomorrow. Just have the annoying task of taking my computer all to bits again. I find I have to take the MB off so I can attach the fans otherwise case gets in the way and is extremely fiddly.
will have to get an 8 pin extension cable to try and sort it out.What would you expect out of a Q6600 on standard heatsink? just got a new rig and want to push it up to 3g or higher but dont want to change the heatsink?
mine OC'd to 3Ghz max load temp i have seem when running prime95 = 50*C (all cores), idle at about 22 - 28* (each core varies slightly).
got an artic pro 7 freezer cpu cooler.
wow thats high, mine idles at 21 ish and when loaded about 30 tops!!
