Using lists in Sharepoint - fixing the width of columns
31 Dec 2003
Stoke on Trent
Hi,
I would like to create a list with fixed width colums, but dont want to have to modify Schema.XML files etc to risk messing up my other lists, do you think its possible to purchase a web part of a list which has pre-defined or even user-defined fixed widths for the fields in a list?
thanks.
No I havn't, but thanks for the tip - does it work with 2003 do you know? I should have mentioned the version in the 1st post sorry.
Unfortunately I don't know. What I do know is MOSS is extremely anal about connecting to older services and vice versa :)
SP is a fantastic tool once you get C# programming going on top of it! Infact I'm actually working on something at the moment :)
Have you got access to SharePoint Designer?
If so, you can adjust the pixels manually :)
Hi Dark,
i've downloaded Sharepoint designer but can't for the life of me figure out how to adjust the column widths as you suggest, could you point me in the right direction please?
what exactly is it your trying to do ?
you can customize a view of a list and then limit the column sizes within that?
you can create a dataformwebpart and style that ?
its quite easy to mess around with the style of 1 list and not affect the others?
as for the bog standard list view i dont think you can limit the column size and really not sure why you would want too, however most people (in my experience) don't display that as they want it to look a certain way to users.
perhaps if you can expand i can try and help further.
alternatively wait for the answer of the original poster
Trying to make it so that if a user enters loads of text in one field that the list web part won't expand to the right, which can get massive and cause a scroll bar to appear in your browser. I want to fix the width of some columns.
I looked at that but couldnt see how?
not sure what that is, not sure if i have that webpart installed? I have a content editor web part and a data view web part?
hope that helps explain a bit more? cheers for the help so far. :)
I wouldnt recommend fixing the column widths but thats your call use the following instructions from the top of my head.
open up sharepoint designer.
goto lists and select your list.
open up the view you want to edit
switch to code view and you should have a ListViewXml tag edit the td elements within this.
if you dont have a listviewxml tage right click on the listview within designer mode and select "convert to XSLT data view"
check in and bingo.
disclaimer : obviously do this on a dev server and take all precations you can as I wont be held responsible if it all goes wrong.
I think i'm being thich here but I can't understand how to do this stage.
^^ thats where i'm at....
just double click on the allitemssg SPD should open up a new page
the other pages are for the forms associated with the list if you wanted to customise them also.
