9.1's out!
What is the difference between the Cats AA settings? There are a few different types of AA you can use along with adaptive AA which I know about.
Michael
been crashing all the time with the 9.1's, same as a friend of mine that has a 4870x2 also. resolution changes or alt+tab usually endy up with a black screen, or frozen desktop and the only thing to do is power off.
gone back to 8,12's and all probs have gone.
DriverCleaner and DriverSweeper in particular is written by a bedroom programmer who has never even seen inside ATI's or Nvidia's driver development labs.
This guy has decided in his own mind what files, system files and registry entries are no longer needed after an install and wrote a program to delete them PERMANENTLY with a blanket approach to all OS's. This same guy admitted he had little time to check for bugs on his forum at Guru3d.
When you uninstall ATI and Nvidia drivers some remnants are left behind granted, but has anybody thought that they may get left behind as they may actually have some relevance to your system and not as some conspiracy to ruin your system by Nazi driver programmers? How does this guy know that what is left is not needed by the OS to configure your system correctly or ensure compatibility with certain OS hotfix's,Patchs etc the next time round? There are a lot of people using sweepers struggling with install errors and one one gpu of their crossfire setups getting installed. I've never had these errors but I just install over the top.
The other reason people use Driversweeper is that there is some paranoia that all HDD's are incapable of overwriting files without corrupting it somehow and merging two drivers into one and losing you 3 fps per game. Here's the thing deleting a file does not actually remove it from your HDD..... Its still there but just flagged as ok to overwrite it. Now unless Driversweeper zero's that file it will MAKE NO DIFFERENCE as to whether everybodys obviously flaky HDD's will corrupt the data it writes.
Drivers are unified so all the files remain the same so only the data contained within those files is changed during a driver update. If your HDD is prone to corrupting an overwrite at will be just as prone to corrupting writing data to a empty section of your HDD, in other words its borked.
My last 8 driver updates I've done in one click and one reboot with my settings for my 4870x2 left intact everytime. God knows why people insist on making life exponentially more difficult for themselves.
+1 ;)
Been having problems with fallout 3 crashing randomly with 9.1's. Gone back to 8.12 hotfix & all seems well.
Going to stick with the hotfix for now, will wait & see what peoples opinions on the next drivers set are before upgrading probably.
This is the first time I've had a problem with ATI's drivers
Installed the 9.1's last night and having big problems in mirrors edge, the game freezes for about 2 seconds every 10/15 seconds. Few games in steam dont seem to be running as smoothly as pre 9.1's
Back to the 8.12's for me too, I went to previous drivers on the ati site to get the 8.12's, do these include the hotfix or is that a seperate download?
great so the beginning of is yeah download more frames in games, and now people moan about it not working :(
Download or not Download is the question?
i got a ATI 4850
Well, here's a counter argument....
When I used to just install new ATI drivers over the top of old ones everything seemed to work correctly but then I'd use an app like Rivatuner and find that it enumerated several orphan graphics card entries that as far as my registry/system was concerned still existed. It even had my old X800 XT listed that I had removed from my system a good 6 months+ prior.
Then at other times I'd uninstall the ATI drivers manually and reboot only to find Windows still managed to find old .inf files lying about and just reinstall the device using them - result: a semi-functioning graphics card with no CCC to control it with.
So now I've just taken to uninstalling the drivers, rebooting to safe mode and running Driver Cleaner .NET - the net result is that when I boot back into Windows it can't find any drivers for my graphics card (good!) and I can install whichever Catalyst package I'm upgrading to seamlessly. Using this method even Rivatuner - amongst other things - doesn't enumerate loads of stray non-existant graphics cards.
So - it works for me. Your mileage may vary I guess?
Incidentally a bedroom programmer (not sure how this is relevant when you consider that even ATI/Nvidia have released buggy drivers in the past) can quite easily hook system events to work out *exactly* what is added, amended or deleted when you install something.
In XP I'd agree with you to some extent, but that OS always needed you to wipe its ass after it did anything. The advancements Vista has made in driver management mean it's no longer needed. All the issues I read on forums with ATI cards tend to be Vista and Crossfire owners using Driversweepers. It caused me problems which only a format solved.
A good tried and tested registry cleaner such as CCleaner that physically scans for redundant registry entries and provides you with the faciltity to backup before you nuke any errors would do the trick and solve the issues you appear to have had. Incidentally, I haven't seen the behaviour you have with rivatuner and it may be worth going to Guru3d forums and ask Unwinder over there why that is the case as he wrote the program.
I don't think there are any issues with sweepers and Nvidia owners that I can detect so the software may work as intended there.
If you don't want your OS to reinstall previous drivers after a uninstall go to device manager and uninstall your hardware from there, selecting delete driver software in the process. I would recommend anybody currently having install issues to do this before uninstalling driver software in Programs and Features.
Vista was designed originally to update drivers without needing a reboot at all, but current hardware designs sadly dictate that a re-boot is needed to re-initialise the hardware.
When was the last time Nvidia or Ati released drivers that hosed OS installs as I can't remember that ever being the case. But by all means I'd be happy for you to point that out to me.
Whats the recommended way to "roll back" the ATi drivers?
Updated to 9.1's when they came out, everything seemed ok although in most games i noticed a small drop in FPS not an increase.
Big problem is CoD 4 & 5 stop working and close after 4 or 6 maps, never during a game, always as the map is changing?
Any ideas?
Found this in the problem solving thingy;
Problem signature
Problem Event Name: APPCRASH
Application Name: CoDWaWmp.exe
Application Version: 1.2.1054.0
Application Timestamp: 4983a2b1
Fault Module Name: atiumdag.dll
Fault Module Version: 7.14.10.636
Fault Module Timestamp: 496d6d9d
Exception Code: c0000005
Exception Offset: 0004ad03
OS Version: 6.0.6001.2.1.0.768.3
Anyone else having this problem with 9.1's or is it something else?
Problem signature
The 9.1's are crashy full stop. I'd use the 8.12's if I were you.
Weird, I've had no problems with any games since moving to the 9.1s
Mirrors Edge = fine
Burnout = fine
Fallout 3 = fine
TR:U = fine
Flatout = fine
POP = fine
Guess I'm just lucky :D
I've had no problems with the 9.1s either.
Looks to me like kitch9 is crashy full stop. I'd login as kitch8.12 if I were you.
To be honest about Drivercleaner, Driversweeper, Driverexterminator or whatever you want to use, I don't see how it particularly helps, I've switched from ATi <-> Nvidia on a few machines on multiple occasions with no problems, it's not like it's going to suddenly install a Nvidia driver for an ATi card or vice versa, otherwise, why don't we clean USB drivers that are installed etc?
Surely all that is needed is a standard uninstall. I thought we're passed the age of worrying about extra files in system32 or a few extra registry entries given in the grand scheme of things they make no difference to performance of a machine.
