Excel formula wanted please
Man of Honour
29 Mar 2003
Blurton
C'mon lads make me look good in front of my bosses again.
I want to take somebody's birthday eg 29/05/1958 and turn that into showing their age from the date when I open up the spreadsheet (perhaps in years & months but years is OK).
If there is a certain way to input the DOB then also mention that please.
Thanks
here you go mate
=DATEDIF(A1,TODAY(),"Y") & " years and " & DATEDIF(A1,TODAY(),"YM") & " months"
just enter DOB as dd/mm/yy and excel should format it correctly automatically
here you go mate
I've entered the date into A1 as 29/05/58 and up came up as 29/05/1958.
(I then changed the format so it read like the first one)
I've put the formula into A2 and B1 but it doesn't want to work for me.
Help
what does it come up with? (error or just the wrong thing)
I just did this in excel 2k7 and it worked, the only thing I did differently was not changing the date format although that shouldnt make a difference as excel will just convert to numbers anyway
Help
Don't see how it can't work as its a very very simple forumula (A quick google shows the googled page he got the forumula from: http://www.ozgrid.com/Excel/calculate-age.htm).
It's most likely your date format (i left mine as default - *14/03/2001 in excel 2007, although having the format as *14/03/01 works just the same).
I didn't find that link, found a similar one and had to mess about with it! Oh well, it killed 5 minutes at work, only 15 to go :)
I have just tested here and it works fine, nice formula :)
One thing I found that may be your problem... On my first attempt I copied the formula from above and pasted directly into B1. This made the cell blank and did not work. I then deleted the column and tried again, but first pressed F2 so I was editing the cell B1 and then pasted the formula in. Then it worked fine.
Since I was copy and pasting from the above it was in white.
I just changed the font to black and it was there :)
THANK YOU VERY MUCH
More help please.
Once again a massive thank you for your input because this will totally enhance my spreadsheets and others in the Skills Academy.
eg I deal with mainly 14 to 16 year olds and their age depends on where I can place them and when.
Next question -
My column with the formula shows 109y 1m if I don't input any data.
How do I hide that cell until I input data?
Thanks
Hi,
I am not sure if this is the best way, but you could place the existing formula into another IF statement, checking that the value of your date if greater than zero. (Dates in Excel are stored as numbers starting from 01/01/1900, so this date is 1)
=IF(A1> 0, DATEDIF(A1,TODAY(),"Y") & " years and " & DATEDIF(A1,TODAY(),"YM") & " months","")
Hi,
Brilliant - works a treat but I have shortened it a bit so it reads eg 22y 7m
Thanks once again
Glad you have sorted it and the thanks should be directed at Ricky1981, he came up with the original sound formula :)
