10 Feb 2009 at 18:19 #1 b-star b-star Associate Joined 13 Nov 2008 Posts 1,032 Hi. wonder where to connect better case fan: 1) CHA_FAN or to 2) PWR_FAN and what is the difference! cheers
10 Feb 2009 at 18:25 #2 ~Divine~Wind~ ~Divine~Wind~ Can't type for toffee Don Joined 14 Jun 2004 Posts 17,583 Location Newcastle U/T CHA - Chassis PWR - Power Supply Isnt it so you can connect the fans to monitorable power?
10 Feb 2009 at 19:01 #3 bremen1874 bremen1874 Soldato Joined 20 Oct 2008 Posts 12,081 IIRC all the fan headers on the P5Q-E support monitoring and automatic speed control except for the PWR header that just supports monitoring.
10 Feb 2009 at 21:28 #4 b-star b-star Associate OP Joined 13 Nov 2008 Posts 1,032 Thanks! already have connected to CHA_fan1 can I control speed? I tried in bios, I couldn't from there!
10 Feb 2009 at 21:44 #5 Kennysevenfold Kennysevenfold Soldato Joined 9 Sep 2008 Posts 7,940 Location Glasgow b-star said: Thanks! already have connected to CHA_fan1 can I control speed? I tried in bios, I couldn't from there! Click to expand... dont think you can manually set the speed, it just varies with the inside case temp to keep noises at a minimum
10 Feb 2009 at 21:47 #6 bremen1874 bremen1874 Soldato Joined 20 Oct 2008 Posts 12,081 Look for Q-Fan Control on the Hardware Monitor page of the bios. You can't directly control the speed of the fans but you can configure the board to control the fan speeds depending on the temperature.
