*Final* spec check, Buying tomorro***
30 Jan 2009
UK
Hi guys, Finalised my items for my new system which ill be building, Hopefuly ordering tomorro, any comments or changes i should make before i go ahead ?
AM i missing anything that i need to build my system, Anything else that i need to order, Appart from keyboard, DVD drive and HD.
I have no idea about the make of power supplies.. can you guys enlighten me, why not an ocz power supply ? if not the one ive chosen, which one ?
Guys i dont even do any of that stuff...
This setup is costing me basicaly the same as another setup i had ordered before.. and it was a two duo.. and a crappy board.
Beats me.
Still looking at power supplies, dont really want to push the boat out on a Hugely expensive one.
Budget is £900, Didnt get much response last night, oly from one or two, would like more advice from a greater range of people :]
tbh a Core2Dou/Quad system would be better suited for you as you do none of the things most do with an i7.
Spec you up one in a min.
What size is your monitor?
You could save about £200-£300 by going core2 duo/quad, which would be just as good as i7 for what your looking to do with the PC.
Something like the above would be good. Add a CPU cooler to it and get a decent overclock on the Q9550.
With the money saved get yourself a 4870 or gtx 260-216 (sell the 9800gt for a bit more cash aswell).
You could save even more money and go for an E84/500 dual core CPU, particularly if it's a gaming PC.
I'm now quite jealous, after reading two i7 upgrade threads :(
Spec looks good though, change the PSU !
