If you just want the TaskMan, Ctrl-Shift-Esc is easier![]()
Right clicking the task bar and selecting task manager is even easier .![]()
Who said anything about task manager? Some of us used PCs when Ctrl+Alt+Del did something! When you've got a whole manufacturing hall full of PCs to reboot doing it one handed is far easier.Right clicking the task bar and selecting task manager is even easier .![]()
What if your mouse got eaten by a cat what would you do then?
Highlighting text as i read it, section by section.
No idea why!
What you're telling me you can't hold down ctrl and shift with your thumb and reach esc at the same time with your second finger?Not that easy with one hand unless you have long fingers.
That's why I said 'if you just want TaskMan'. Obviously, ctrl-atl-del has it's uses.Who said anything about task manager? Some of us used PCs when Ctrl+Alt+Del did something! When you've got a whole manufacturing hall full of PCs to reboot doing it one handed is far easier.
i always close apps by double clicking the top left (from windows 3.11)
i get weird looks from my boss when i do this
I refuse to drag the scrollbar to navigate. I'll either use the mouswheel, middle click and drag, or hit pg up, pg down, home or end.
I also never click the Back and Forward buttons in explorer or Firefox, I only use the sidebuttons on my mouse.
You'll like Windows 7 then: Drag to left or right edge - window size is changed to fill exactly half the screen.
(Also, drag to top to maximise. Shortcuts for all of these are Windows Button + Left Arrow/Right Arrow/Up Arrow).
When i turn my pc on and windows hasnt even loaded yet,i open paintshop,media player,msn bitcomet and anything else i want. . . only to be waiting even longer![]()
