Thinking about the following:
Antec Fusion Remote HTPC Case
Asus P5Q-EM
Plus CPU, Ram etc.
The key questions.
What HD Freesat dual tuner cards would people recommend that will fit in the case. I will probably be running Vista Ultimate on this or maybe XP plus Media Portal. So ideally the tuner card would be compatible ith both OSes and also importantly fit in the case !
Can the motherboard put out audio over a HDMI connection to my TV ?
How good is the onboard X4500HD graphics - will it be able to deal with 720p/bluray decoding ?
Also I will be using this as a replacement for my HD SKY+ box so I want it to be able to record 2 HD channels and playback 1 HD recording at the same time. Will a decent CPU be able to do this and will it get any encoding/decoding help from the X4500HD chipset ?
Cheers !
Asus P5Q-EM
Plus CPU, Ram etc.
The key questions.
Cheers !
