Cheap pc upgrade for my parents
6 Oct 2004
England
Hey, my parents pc(that i built about 3 years ago) needs upgrading.
Now its an old amd althlon 64 so i need pretty much everything apart from a case.
Looking at around £350-400 max?
It will be used bascially for email/banking etc etc, no gaming as i've left home now :p
Any ideas? Thanks
Any ideas? Thanks
how about a format and reinstall, if they are just banking and email, then my old 400mhz cpu can do that.
waht the current specs
22 inch might be worth looking at, same res but larger image makes it easier to see if eyesight is an issue
Its making lots of weird noises, plus they just want to upgrade in general for vista (dont ask, just...DONT ASK)
They are currently using an old school either 17 or 19" crt and have no problems viewing so i think a 20" widescreen will be ok :)
No need to go with a processor that high spec, go with something down the E2xxx range, they work fine in a lot of workstation PCs we put out...
EDIT: Didn't notice the AMD mobo :P and the minute price difference on the E2xxx to the E5200 :(
This would do them fine in regards to CPU.
This would be perfect for PSU.
Told you i had been out of the game for a long time, what processor/mobo do you reccomend?
Just need something to run vista home premium nicely (Is it worth getting the 64bit version)?
New spec what do you think.
I shouldn't need any thermal compound should i?
Asus VW202SR 20" Widescreen LCD Monitor Asus VW202SR 20" Widescreen LCD Monitor £111.54
(£96.99) £111.54
Microsoft Windows Vista Home Basic SP1 64-Bit - OEM (66G-02141) Microsoft Windows Vista Home Basic SP1 64-Bit - OEM (66G-02141) £71.29
(£61.99) £71.29
AMD Athlon 64 X2 Dual Core 5200 2.70GHz (Socket AM2) - Retail AMD Athlon 64 X2 Dual Core 5200 2.70GHz (Socket AM2) - Retail £52.89
(£45.99) £52.89
Akasa Ultra Quiet 400W Paxpower Active PFC ATX2.2 Power Supply - Black Nickel Akasa Ultra Quiet 400W Paxpower Active PFC ATX2.2 Power Supply - Black Nickel £40.24
(£34.99) £40.24
Foxconn M61PMV nForce 430 (Socket AM2/AM2+) PCI-Express DDR2 Motherboard Foxconn M61PMV nForce 430 (Socket AM2/AM2+) PCI-Express DDR2 Motherboard £37.94
(£32.99) £37.94
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) £19.54
(£16.99) £19.54
Sub Total : £289.94
Shipping cost assumes delivery to UK Mainland with:
DHL @ Home Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £9.99
VAT is being charged at 15% VAT : £44.99
Total : £344.92
Product Name Qty Price Line Total
Microsoft Windows Vista Home Premium SP1 64-Bit - OEM (66I-01939) £91.99
(£79.99) £91.99
(£79.99)
Abit IP35 Pro XE Intel P35 (Socket 775) PCI-Express DDR2 Motherboard £65.54
(£56.99) £65.54
(£56.99)
Intel Pentium Dual-Core E2200 "LGA775 Core 2" 2.20GHz (800FSB) - Retail £57.49
(£49.99) £57.49
(£49.99)
Western Digital Caviar Blue 250GB SATA-II 16MB Cache - OEM (WD2500AAKS) £40.24
(£34.99) £40.24
(£34.99)
Antec Basic 350W Power Supply £33.34
(£28.99) £33.34
(£28.99)
OcUK GeForce 8400 GS 256MB DDR2 HDTV/DVI (PCI-Express) - Retail £25.29
(£21.99) £25.29
(£21.99)
Asus TA-861 Midi-ATX Case - Black/Silver (No PSU) £21.84
(£18.99) £21.84
(£18.99)
OcUK 2GB (2x1GB) PC2-6400C5 800MHz DDR2 Dual Channel Kit £18.39
(£15.99) £18.39
(£15.99)
Samsung TS-H653F 22x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £14.94
(£12.99) £14.94
(£12.99) Sub Total : £320.91 Shipping cost assumes delivery to UK Mainland with:
(This can be changed during checkout) Shipping : £9.99 VAT is being charged at 15% VAT : £49.64 Total : £380.54
jobs a good"un
(£79.99) £91.99
(£79.99)
(£56.99) £65.54
(£56.99)
Intel Pentium Dual-Core E5200 "LGA775 Core 2" 2.50GHz (800FSB) - Retail £62.09
(£53.99) £62.09
(£53.99)
(£34.99) £40.24
(£34.99)
(£28.99) £33.34
(£28.99)
(£15.99) £18.39
(£15.99) Sub Total : £270.94 Shipping cost assumes delivery to UK Mainland with:
(This can be changed during checkout) Shipping : £8.99 VAT is being charged at 15% VAT : £41.99 Total : £321.92
Cheers kenny i will order that later today proberly :)
I have a 6800 gfx card, old school i know, but it be used for gaming anyway!
No, i belive the card is running via agp
edit: oh that mobo doesnt have agp does it?
I have this, just need a motherboard and processor
Samsung SM2053BW Aqua 20" Widescreen LCD Monitor Samsung SM2053BW Aqua 20" Widescreen LCD Monitor £123.04
(£106.99) £123.04
(£61.99) £71.29
Western Digital Caviar Blue 250GB SATA-II 16MB Cache - OEM (WD2500AAKS) Western Digital Caviar Blue 250GB SATA-II 16MB Cache - OEM (WD2500AAKS) £40.24
(£34.99) £40.24
Antec Basic 350W Power Supply Antec Basic 350W Power Supply £33.34
(£28.99) £33.34
(£16.99) £19.54
Sub Total : £249.95
DHL Select Next Day (Delivered Mon-Fri)
VAT is being charged at 15% VAT : £38.84
Total : £297.78
