Does anyone use this block on your GTX280 and if yes, how did you take the stock cooler off and mount it on? I'm going to do it and don't want to break anything, cause may need to put stock cooler back on some time in the future...
I did a 295 the other day, thats a dual card as you know. It took me about 1hour for just the block installation.
As long as you are careful and methodical you wont break anything. Just follow the instructions, it shows you step by step. Also make sure you have thermal paste and dont forget to apply it![]()
just remove all the scews with springs on, dont remove the 4 scews that hold the core surround on. When you have done it right, the card should rotate left and right from the heat sink(then its free). To get it off, you will need to give some lefting force on the edges as the old thermal paste holds tight for a bit.
This will help you...
http://www.techpowerup.com/reviews/Zotac/GeForce_GTX_280_Amp_Edition/6.html
