Hi there,
Well I thought i'd give water cooling a go for a laugh and being my first time the parts i've chosen are probably a bit over kill, but I guess its gives me head room for expansion. I have had a quick read of the sticky and followed some links off of that to get a rough idea of what I could need. I'll only be cooling the CPU to begin with which is currently an E6700.
The bits i've chosen:
XSPC DDC 10w Pro Pump/Reservoir (£58.74)
D-Tek Fuzion V2 Universal CPU Block (£46.99)
XSPC RS240 120mm Radiator - Black (£23.49)
Sharkoon Silent Eagle 2000 120mm Fan - 3/4 Pin x2 (£16.42)
D-Tek Fuzion v2 Quad Core Mid-Chamber Insert (£5.86)
Feser Aqua - Ultra Pure Water x2 (£9.38)
XSPC 7/16 UV Clear Blue - 1m x2 (£5.86)
Del (8.95)
Total 177.25
I've included the quad core insert just in case I acquire one shortly. The case that this will all be going in will probably be the spare Gigabyte GZ-X2, I currently use that for testing bits and bobs . Looking at the case i'm going to have to dremel the top for the radiator. its going to be a tight fit up the top if I mount it inside though.
I own a few large Lian Li cases, V2100+ and its predecessor etc, but don't want to be installing in them till I have things working 110%.
Anyhow, is what I have chosen ok? Anything I should change to maybe lower the price but get the same performance? Oh and I 'm a tad confused with the barbs/connectors to match the tubing.
Thanks in advance
Del (8.95)
Total 177.25
Thanks in advance
