182.06 Drivers
13 Jun 2007
Chesterfield
Could anyone please tell me if its possible to get the control panel from 180.48 drivers into the the 182.06 drivers?
only up to the 180.48 drivers that the HDTV resize option actually works properly, so ive been having to stick we old drivers and miss out on the better performance speed in games with the new ones!
nvidia are proper useless!
move the mouse cursor in the middle of desktop and press right click and see " Nvidia Control Panel" if you have one -- I have one already and the resize itself once Ive installed new drivers into my Samsung 40" LCD TV (1920x1080p @ 60mhz) - when it came back and the size was 16:9 so I changed to Just Scan that prefect size.
You could try unpacking them with winrar and putting the unrared files into a folder
then use device manager/display/name of card/right clclick properties update driver
and point it to the folder you just made.
worth a try
im crap at explaining things, to cut story short, the resize option in the drivers after 180.48 drivers don't work properly at all! and extremely annoying!
You could try unpacking them with winrar and putting the unrared filews into a folder
worth a try
just had a look through and havent got a clue what files will be to do with the control panel or resize options :/
just left a message on the nvidia forums, doubt ill get a reply as you never do we them! if it doesn't get sorted i think ill just have to try out ATI for first time :)
quick noob question is "forceware" the actual drivers? or is it something that goes with the drivers?
EDIT dunt matter
and now they are called GeForce drivers. :)
and there completely utterly ****!
when are next gen of ati cards out? can wait because the old drivers i am on now are still flying through any game they touch but adoubt they will in 6+ months! will they?
