in all honesty, the OP did state clearly in the thread title what it was about, therefore if you did not want to answer the question, you should not have clicked on the thread. Although i do see where both sides are coming from, and it was only advice you gave. Its infomation easily found, but we all ask silly/easy questions sometimes, and there are many different opinions.
anyway, that aside.
ive never tried watercooling, but i find air cooling more than enough for a pretty major overclock if done well. Only reason i would ever get watercooling is if i wanted to make my pc look seriously kickass, rather than practical.
im currently at 3.6GHz on a Q6600 using a Tuniq, which has only one fan that i cant hear. so, you dont need watercooling to get a good clock, although as i said above, it looks epic
anyway, that aside.
