MY FIRST BUILD EVER - GAMING PC - 4 MONTHS OF BUILD - STORY!
13 Nov 2008
MY FIRST BUILD EVER - GAMING PC + PICTURES - 4 MONTHS OF BUILD - STORY!
Well, on November 2008 I desided to build first custum pc!
Spect used to be following:
-Vista Ultimate 32bit
-E8500
-Asus P5Q-E
-SAPPHIRE X1950 pro (from old system)
-480 x-power psu
-2 x 1Gb Ocz Platinum 800mhz RAM
-Seagate Barracuda 32mb 500GB
-Thermaltake Aguila VD1000SWA Aluminum Case
-Sony Dvd-Rw Rom (from old system)
-Card reader
after I have finished it looked like this:
nothing special, but worked!
after one week desided to ad 2Gb of Ram so total 4gb!
and desided to change to VISTA ULTIMATE 64bit
as X1950 pro is outdated for new games...
I purchased HD4870 512mb O/C edition with Hyper 580W PSU (on Sale) as mine 480W
was Unbranded and low
when installed card remved HDD rack to save place and put HDD to internal 3.5" bay
-was happy but wanted to get better graphic and got GTX260 216 (on advise, on sale)
which was making mad squealing...so I RMA'd it
and started to use again Hd4870!
later did O/C...so because of the temperature issue wanted to get CPU cooler, but before that got GTX280 as it was crazy OCUK SALE: £215, so:
and after got cooler:
so, sold mine X1950 pro and HD4870
... Hiper 580W was not very stable with GTX280 because of cables:
so, sold HIPER
and Got PC POWER & COOLING 610W PSU:
when opened the box was dissapointed as all cables where together and no chances to remove unwanted like on hypper, but once installed is good!
added also:
and:
-Scythe Kama-Bay System/Hard Drive Cooler - Silver
-Akasa AK-174BKT-B 120mm Auto Thermal Sensor Black Case Fan - 3 Pin
-blue cold cathode ligh
showproduct.php
OMG- cable management was eve worser than on very first picture, but did cable management: put wires behind motherboard, hdd, dvd-r, psu
and finally:
-Vista Ultimate 64bit
-E8500 3.8ghz
-Coolermaster Z600 (cpu cooler)
-Asus P5Q-E
-Zotac GTX 280
-PC Power & Cooling Silencer 610W
-4 x 1Gb Ocz Platinum 800mhz RAM
-Sony Dvd-Rw Rom
-Card reader
all upgrades took about 4 months...
will edit a bit later if find something what I've missed!
I'd be interested to find out how was it like building you pc with that case. I bought a Thermaltake Soprano long ago, and thought it the worst case ever. The PCI clippy thingies really annoyed me though.
You went from Hiper, a known bad PSU to an equally bad, unbranded one? Suggest you get that out sharpish and go with something like a Corsair...
PC P&C are very good PSUs.
To OP: Loved the story :) but bloody hell i wish i had that money to change gfx like every month :(
Edit: Can you attach a fan to CM Z600 cooler?
Well done for your first build.
The case is not really my taste and I do like it more if the PSU sists on the bottom, I think the cable management can be much improved and if I were you I'd get rid of the IDE devices, removing those big cables really cleans up. Next time, I'd go for a modular psu! ;) Anyway gratz for getting your first build up and running!
if you are unable to remove the IDE cables then have a look around for some rounded IDE cables. then again the cost of a SATA alternative these days is minimal.
with cable management i find its best to build the system, plug in everything then move the cables around to have few of them showing. go down to your local hardware store and get a pack or 250 cable ties for £4 :p
