Help me overclocker my new AMD Phenom II X3 Tri Core
8 Jun 2006
Hertfordshire
Hi guys
I have changed the multiplier to 17 (I think) clocked to 3.4 at the moment with stock everything!
Idle temp is 24 according to Coretemp although its only showing CPU#0?
Whats the next move from here to get it up to 3.8 say?
Asus M3A79-T Deluxe AMD 790FX (Socket AM2) PCI-Express DDR2 Motherboard
AMD Phenom II X3 Tri Core 720 Black Edition 2.8GHz (Socket AM3) - Retail
just up the multipler untill it fails/doesn't post then go down 1 multi and boot in to windows, run prime95 for 2 or 8 hours then if that pass and if u want to overclock more just bump up the voltage alittle.
Phenoms only have 1 temp sensor..
what cooler do u have?
idle 24 at the moment, what's the best stress test? orthos?
yes or prime95
just be careful if u bump up the volts
at stock volts my 940 idles at 25c, 34c underload but with a small bump up on the volts +25.0mv the temps go to idles at 30c, 60c underload with running prime95 only for 15min :confused:.
i know yours a 720 but basicly the same just as 1 core less.
What's the most reliable CPU temp monitoring software? Coretemp?
Coretemp reads my cpu @ 25 idle
Speedfan read it @ 34 idle?
Hi guys
Can get to 3.5ghz with just multiplier overclock then it won't boot?
Set the settings below, but should I be upping the north bridge to assist in overclocking? If so what volts do I start with on my board?
Temps idle are 25 and 30 load so temp isn't an issue at the moment :)
Any advice would be great ;) I really want to see what this chip is capable of but stability is key
Disable Cool ‘n’ Quiet
Disable C1E
Disable Spread Spectrum
Disable Smart CPU Fan Control
Manually set Memory Timings
Windows Power Option and High Performance
