PC ON or OFF??
12 Jan 2009
hi,
Just woudering how good this is for the PC! at the mo i am continually allowing power to run through the PC even when it is off! i do this beucase i belive that turning it on and off at the plug could cause damge to the compoents! so just asking wat do other people do?
regards
Hi mate,
it doesnt cause a blind bit of difference. and if you dont mind it , it doesnt kill the bank either.
:D
Regards
Angelosn
The only reason to switch a PC off at the mains is if you're worried about the tiny amount of electricity it'll use providing the standby voltage to the motherboard.
If nothing else leaving it plugged in will stop the motherboard battery going flat.
hi,
regards
I've always just used a PC with the power constantly plugged in & on at the wall. Never had a problem.
i turn the power of at night but thats only because my stereo has a flashing lights sequence (the stereo is on the same extension lead as the pc)
I nearly always just turn it off.
If I'm leaving it for a few minutes I'll put it into sleep mode. I'm getting really obsessive about it being on when it doesn't need to be...:p
Mine's always on as well :P
Though I used to always turn it off at the plug as well, only because the psu had a very annoying buzzing sound when left on, so yeah that had to be turned off for me to sleep!
I didn't know this and thought that the mobo battery is used when the PC is switched off (but still plugged in at the socket) :confused:
Only when there is not a live current from the PSU, such as transporting your rig, or power outages. Would be a PITA to have to reset your BIOS ever time your PC lost power!
It used to be a problem, in that powering your computer up & down would result in "Socket Creep" or "Chip Creep" due to thermal expansion. However, nowadays this is not really a problem due to improved cooling & retention. I guess it just depends on whether you can afford the electricity and/or cope with the guilt of destroying the planet?
