Baffling.
12 Jul 2005
lol 3DMark06 registers a LOWER mark when my CPU is overclocked to 3.2MHZ when compared to default settings of 2.4 MHZ.................... im confused.
Is your RAM linked? If so and you havent adjusted the multiplier its possible the RAM is unstable with the OC and that is affecting your overall score
The comeback of all comebacks. I shall write it down as a reference when I am scratching my head desperately for a witty reply to a cutting post. I thank thee.
No problem! I on the other hand will disregard your comeback as insipid & uninspiring.
By the way, I think you forgot to include the word "for" in your masterful repost? - "I shall write it down as reference FOR when I am scratching my head". Otherwise it just makes you sound like a bit of a simpleton to be honest.
spitzoid just give it up... you tried to be funny with your first post, failed miserably, and now it's just getting embarassing as you desperately try to cling to your e-pride. Please just add to the discussion and help the OP, or stop posting...
e-pride is in tact thank you, e-bully.
You should listen to your own advice.
Over & out poindexter
