My set up is a Q9550 at 1.37Vcore FSB and NB voltages well below maximum, a Silverstone T07 with extra front fan intake.
water cooling is a PA120.3 with Yate loon 2200s (set at about 1000) in push configuration, a XSPC 750 pump/res combo and a Dtek Fuzion 2 with quad splitter.
idle is about 5C above ambient but load temps are 20C+ above idle when running small FFT in prime95 (usually mid 50s depending on ambient temps).
now i know these temps are perfectly reasonable but ive seen posts on here with people cooling there GPU and NB and still getting less of a delta under load, what could i do to improve my temps......
i have reseated my block 3 times, what is the best way to orientate it?
i have a new pump arriving tomorrow and im going to shorten my looping ( i left it long for testing puposes)
my loop goes pump/res > cpu block> RAD
i cleaned the RAD and bled it before operation.
any ideas?
edit. would the orientation of the quad core insert make a difference as it come with no instruction i just put it in as i though it should go?
also when i take it off lod the idle temps sit 5-10C higher than they were.
any ideas?
